Locate Light level Sensor
Arron1970
Just got a call from the garage who are doing a service on my E85 - apparently I need a new light level sensor as the old one is held on with a cable tie and in their opinion is probably not sitting quite where it should be leading to probably non optimal adjustment.
I'll obviously have a look in the region of the light areas when the car gets home tonight to try and suss if I can get away with just a new bracket or a whole sensor - but does anyone know where this sensor is located? And is there one for each side?
Cheers in advance
Arron
Cheers in advance
Arron
I think it’s on the r/h side where the wishbone joins the chassis area, just the one :thumbsup:
Cheers in advance
Arron
Cheers Rob, I'll have a scan in that area tonight!
Yep. It's a black box that joins the front right wishbone from above. You'll see it has a small Bush and probably snapped off the small bracket. It can't be repaired and about £90 for a new unit.
There are two on the e85
Rear right and guessing front right.
My rear one is broken so that a job for later.
I got a pattern part off eBay for £20
Cheers for the responses guys - had a quick look last night but didn’t locate it. Will need to jack it up this weekend!
Found this one on eBay - looks good value
https://www.ebay.co.uk/itm/XENON-HEADLIGHT-RANGE-LEVEL-CONTROL-SENSOR-FITS-BMW-1-3-5-6-7-X5-Z4-Z8-MINI/162475697540?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52945%26meid%3Dfe38f31bd40849839e1bfe28387f4061%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D132113830684%26itm%3D162475697540&_trksid=p2047675.c100005.m1851
