List of faults 17k mile, 56 reg Z4M Coupe
Status
Not open for further replies.
Mrbodger
 Nottinghamshire
Went to look at the above today, the car is in excellent condition apart from some kerbing and a couple of minor scuffs.
However, I found after visiting the local dealer to check on the history, it had had quite a bit of warrenty work done;
New rear spring
New aerial for sat nav
One new ignition coil
O2 sensor
Repaired headlight cleaning system only a nozzle
Removing and installing or replacing final drive
New power steering pump
New front seat mechanism
Re routing control line to electric fuel pump
New rear pads and discs
Do I buy thinking that it's now a sorted car or run a mile?
It's a lot for a low mileage car, but some of those items may well be due to it not getting proper, long runs and the spring is a common issue.
Discs & pads are consumables.
Nothing there would worry me, and if it still has warranty there's nothing that should worry you.
Thanks for the speedy reply
I've just spoke to the owner and he says a few of them are related to eachother. He had a rear end noise which they couldn't trace and started replacing bits. I know that dealerships can get a bit gung ho when it's a warranty claim cos they make money out of it.
Status
