Managed to get a little time on the car last night and today
A new issue I’m looking to resolve is the headlight levellers
To date:
Car (e86) had a loom issue so I replaced the loom
The only difference in spec between the old and new cars looms was that this car has xenons and the donor loom was halogen lighting
I’ve wired the lights in ok and have functioning sides, main and high beam xenons
In the dark last night I was better able to check the light pattern- it looked wrong and high
I also wired in (from the unit to the LCM) 3 wires for each load sensor (one front one rear) as that was missing from the halogen loom
Now- only the passenger side auto levels on ignition. I will check the wiring and feed on that- it may be a red herring
But the bigger issue is that the front leveller (easier to test) now makes no input to the light beam throw.
To rule that out I put a new load leveller in place and tested again- nothing
So any ideas?
Should I pop a different (halogen) lcm in to see if the beam throw works by the wheel? Do I need to code or wire something else in?
@smorris_12 your views are always helpful
Stuart
To date:
So any ideas?
Stuart
