Light out warning and blinkers speed increased. But no lights out.
Every once in a while this happens on my 05 2.5i. It also mysteriously goes away when I later restart the car. You might try disconnecting the battery for about 30 minutes, then reconnect it. That seems to do some resetting including your driving style settings.
So mine is having the same issue, and the only fault I can find with my code scanner relates to the windscreen sensor. The sensor itself appears to be losing contact with the screen, and it's causing my auto wipers not to work. I reverted the wipers back to normal/intermittent, and the lights are all working, but the bulb sign isn't going away. Very annoying.
