Picked up a set of aluminium bell housing bolts from BMW in the week (a tenner) and got the gearbox lined up with the engine. Then I noticed that the engine mounts still needed changing and this would probably be easier without the gearbox attached.
Couldn't see how to do it without removing the front cross member, and briefly considered taking it off for painting. But you have to draw the line somewhere, and I didn't fancy disconnecting the steering rack at this point.
With the engine supported with a trolley jack under the sump (weight spread with a block of wood) I was able to remove each engine mount without fully disconnecting the cross member. Replaced with another item from my Strongflex order - shiny aluminium mounts with a small amount of polyurethane.
Back to the gearbox... Slid on easily enough but torquing up the bolts took ages. 25Nm + 130° + 20°. Impossible to use a dial gauge so sharpie marks it is.
Rogue Engineering transmission mounts combined with the new engine mounts should keep that weight from shifting about in corners.
Having had enough of lying on my back I switched to the engine for a change. New spark plugs and Bavarian Autosports ignition coils. Just a shame I can't fire it up while there's no exhaust on the car.
