LED strobing rear lights
My first thought was .... yeah, I’ll put that on right after I install the trumpet muffler.... but then I remembered the old T-Bird or the Cougar had indicators that were sequential so they could be interesting, kind of trashy but cool at the same time.
Do they stick on the bottom edge of the boot lid?
Ducklakeview said:
mac27040 said:
This is the simple kit https://www.ebay.co.uk/i/162652344381
Ordered, erm three lol...
Any pics of where you've fitted the strip?
Mike
double sided tape so this is easy to remove, needs a better solution ie strip needs really to be shorter, i have a mate who might be able to make these to fit. :thumbsup:
Ducklakeview said:
Hmm, wonedr if it would be neater fixed to the underside of the boot lid, and then the cable run along the hinge?
Mike
yes it would look neater but as it might not stay on car perminently its easy to remove as i have it.
dans6490 said:
Ducklakeview said:
That's known as the "T" effect, normally when FL lights are fitted to a pre FL car, and it's not been coded correctly.
Mike
Ok, thanks, that would make sense. I haven’t opened the light to have a look but is this a separate bulb to the brake light bulb?
That is the brake light bulb, it shouldn't be lit unless you are braking. As said, you need someone to help you code the lights correctly, something I can't help with but someone on here near to you may be able to.
Bing said:
dans6490 said:
Mike
That is the brake light bulb, it shouldn't be lit unless you are braking. It's not a dual filament bulb so won't get brighter when you brake like on some cars. As said, you need someone to help you code the lights correctly, something I can't help with but someone on here near to you may be able to.
jamie_z4 said:
buzyg said:
jamie_z4 said:
He lives in Liverpool, so it'll be easier to spot when it gets nicked.
Only scousers are permitted to take the p##s out of the best city in the world. :poke:
I am scouse mate born n bred :lol:
I was hoping that would be your reply. Me too lar. Just lost in Cornwall. :driving:
