LED licence Plate Help
Pauly
 Liverpool
Bought LED licence plate lamps from a Forum Member but i cant fit the buggers :headbang: Dont know if Im having a blonde moment!
Popped out my current licence plate holder and this is my current setup
The problem is the LEDS dont have the same connector and the extension connector doesnt seem to fit my cars connector, hope the pictures make better sence
This is the picture of the box and I have Part A (The Led itself) and Part C (Extension Connector) Do people think I actually need Part D (Alternative Extension Connector) to fit my cars connector
Thanks and sorry for the over use of the word connector :?
Hi mate,
Looking at what you have, it look like your new LED unit is intended to fit within the standard lamp holder, and your new connector harness should plug into where the standard bulb would normally sit :)
Hope this helps
Agreed. Not sure why you get another surrounding though, but the instructions imply that you remove the innner part only.
Yeah I thought that PVR and its a sealed set unit :? Just been on youtube and saw the same product and its a direct plug and play setup as the surrounds are the same size as the oem ones! Think I will give the seller a quick pm :thumbsup:
