LED Halo Ring Issues Amber/White Mix
Robjames
New member
I just replaced the inner halos with white LED, easy enough repair.
One problem, the outer rings are still an amber colour and not sure why.
Are there two separate bulbs for the inner and outer rings?
Attached Picture somewhat shows the issue.
One of them (inner or outer, can't remember which) will be dimmer due to the way the light is transmitted from the bulb to the ring. From your picture I'd say it was the outside ring, but yours look yellower than I remember mine being before I changed to LED. Are they that colour in real life or is it a camera/exposure thing?
I have seen alternative design LED's available for the Z4 on wish and such sites. They look like a plaster wall fitting with two prongs on the end, you push them together to get them in the lamp, then they pop outwards to give the same light to each ring. Have a good old search on Aliexpress etc.
Also noted you seem to live in a sunny locale, palm trees etc, if the rings are plastic you may have some UV related discolouring...
