ZermattV said:When was the last time you saw an 8 series?
Stark said:Live and work in London too, not seen one
Thought it was an option rather than standard fit... unless it's changed since the launch reviewsgannet said:...Doesn't the M235i come with an LSD as standard whereas the M135i doesn't....
PerryGunn said:Thought it was an option rather than standard fit... unless it's changed since the launch reviewsgannet said:...Doesn't the M235i come with an LSD as standard whereas the M135i doesn't....
AIUI, it doesn't exist in the factory-build options list as it's one of the 'M Performance' add-ons which are dealer-fitgannet said:PerryGunn said:Thought it was an option rather than standard fit... unless it's changed since the launch reviewsgannet said:...Doesn't the M235i come with an LSD as standard whereas the M135i doesn't....
I was sure I'd read it somewhere, but can't see it mentioned at all in the configurator - or even in the options list...![]()
uuf361 said:I had one as a rental in Florida in June - it was fine, but unspectacular......
TitanTim said:uuf361 said:I had one as a rental in Florida in June - it was fine, but unspectacular......
Pity it wasn't an M235i I'm guessing if it was rental then it was a boggo car with the slowest engine![]()
Tim.
