Leaky vanos
bluepain
Got a leaky vanos on my 2006 2.0l .
,bottom of the two,
Car runs fine..
60.000mls
However I'd like to address this leak..
So my question is where to get them from,
As I cant seem to find them
Is it just the stealers ..
Or is there another choice..
By 'them' I assume you mean the solenoids and not the vanos units themselves.
If the solenoids are operating fine, just pull them out, clean them and replace the orings. Only tool required is a 10mm ratchet or spanner. Nice easy 10 minute job. I washed my engine down with some degreaser to get rid of the oily muck left behind.
Orings can be found here https://www.ebay.co.uk/itm/252032562654.
No problem.
Double check part numbers before ordering. I did this job on a 2 litre. Not sure if they are the same on the 6 pot engines.
Woops... Just noticed you also have a 2 litre!
