Hi all -after thinking I had solved my leak :roll: it rained today and this time I found the vertical carpet damp under the sill-after reading many leak related searches a lot of times the answer is either cut a slit or drill a hole(neither of which I really want to do)-When I separate the rubber from the plastic trim, water 'squelches' out Is there an alternative solution anyone?-thanks
