Lambda sensor.......
LittleZ4
Evening all, quick question. Bank 1 Lambda sensor 2, would that be post cat?? I'm getting a consistent fault code for this after the codes are cleared.
I'm trying to find a replacement and I'm probably being a tad thick. Is it one per bank and then a sensor after the cat??
Think I've found the OEM part number.......
It's a 2004 3.0i se manual if anyone knows of a good (non wallet destroying) sensor.
Cheers for the quick reply, I'll have a look at that shortly. I did find a Bosch one on auto doc for £43. Looks like it should do the job, the bit that concerns me is that it will do both pre cat and post cat?? Does that sound legit??
