KW Clubsport Settings
Clubsport people, on the front with OEM CSL wheels and 10mm spacers gives a 2mm gap between the tyre and spring perch.
i don't have spacers anymore, i use a 29 offset form wheel... which leaves tyre to perch clearance at around 8-10mm...
I've no idea how you make them fit, 12mm spacers fitted and 2.5 degree of camber and the arch liner has pretty much disappeared in a couple of places :rofl:
im not sure why.... my wheel is much more aggressive an isn't rubbing....
i run the dampers stiff and the ride height is very conservative, tyres are 235, 40 18 . offset 28 ( which is very aggressive and would trash a normally suspended vehicle) and around -2.8 neg camber... zero rub and more than happy to post some pics of the liners too.
im 4mm more aggressive than ur posting with a thicker tyre.... something is amiss here. id guess the liner isn't sitting right.
On 235's also, it's the bit on the inside where the bumper joins the headlight, there's like a step if that makes sense?
If I went another 4mm I'd be rubbing the actual arch?
Hmm I'll have to take some pics and see why it's different? Already 1 click stiffer than KW recommended settings, suppose I could go another and see what that feels like...
i can actually fit my hand in here to the other side.... the squat wide tyres/rims/geo setup make it look alittle more lower up than it actually is.
Ahh that must be what it is then, I thought mine was similar height to yours, I guess it's 10-15mm lower!
Happy knowing that I thought I was doing something wrong!
Cheers Beedub :thumbsup:
your is quite abit lower
as you can see in my pic you can see the back of the wheel well at the 12 o'clock position...
Update, corner weighting and geo completed by centre gravity, excellent work as always :thumbsup:
Car is driving lovely now :driving:
