Knocking Steering issue
subby
Hi,
Ive got a problem with my 03 3.0i.
When stationary - wiggling the steering from side to side produces a knocking sound. Its very hard to pinpoint where its coming from, but it seems like the column/rack area.
The noise is also produced when going over certain speed bumps at certain angles. It doesnt always do it, but when it does its very noticable and really is a nasty clunk/knocking.
So far ive replaced bottom arms (including rear bush), and drop links. Ive checked all inner and outer track rod ends, and everything is perfect with no play.
Now, im assuming the problem is the column, as this is the usual culprit. But im not experiencing the sticky steering issue, this is purely a knocking sound.
Has anyone else experienced this ? Could it be the rack itself ? I cant seem to find anyone else with this specific problem.
The car has been to one local garage who said its the column or the rack, and its also been to a BMW specialist who said its the column.
Thanks!
subby said:
Hi,
Thanks!
Try the strut supports in the engine bay, they often come loose and can cause the noises you are talking about !
thanks for the reply! (sorry just realised its in the wrong section...monday morning!!!)
Do you mean the strut braces or the top of the actual strut mounting ?
Thanks.
Thanks.
Hi, yeah the strut braces..I meant, you've probably checked them ? which section should it be in then ?
Yea i think i have checked them a while ago when it started but will check them again :).
I guess i should have put in in the 'problems' forum and not the 'discussion' one.
Have revisited post, as I had the same issue.
Rocking wheel side to side produced knocking as it seem in actual electric column in cabin.
Long story short:
It is a "vertical" screw mounting column in possition, but it is on some sort of slotted gap for adjustment.
I would need to make a pic maybe.
There are several screws, that tighten column itself - easily accesible from bottom (torx socket)
But there is on at very back of whole assembly - i think it was 13mm
If you lay on your back looking up the collumn (that is how I done it - roof down, legs out) nut is to the right.
I've tighten it about 1/4, mayby more and all knocking stopped.
Hope it helps someone.
Long story short:
Not quite sure what you are referring to?
The column is mounted with 8 bolts, all 13mm head.
The bottom two do indeed pass through an open slotted fixing. This is not for adjustment, but to enable you to put those two bolts in and slot the column in to take the weight while you bolt the rest in. The fact that the other six bolts pass through standard holes means it would not be possible to adjust the column's alignment.
I believe we do talk about the same thing enuff_zed
It was this that "install assist" bolt as you described it in "open slotted fixing", that was source of knocking for me.
OK, so it aounds like yours was a simple case of a mounting not being tight?
Always good to check the simple answers first. :thumbsup:
