alexrives1995
Hi All,
I recently purchased an 07 Z4 3.0si and I am loving the car so far. The car has been used a lot, but it is nothing some TLC can't fix.
The car only has one key, and ever since I got the car the remote on the key did not work, for the most part it is not a huge issue, but it is something that I want to get fixed. I open the trunk and get inside the car by manually using the key.
I have tried initializing, doesn't work. I have tried it using position 1 & 2, with doors locked and unlocked.
I opened up the key itself to replace the battery, but using a multimeter i saw that the battery terminals had 3V across so there was no need to change a working battery.
The inside door lock does work.
At night time the red LED on the rearview mirror blinks, letting us know that the alarm is set.
After work I am planning on checking the fuses.
If anyone has had a similar problem and found a solution let me know! I am hoping to see different things that I could troubleshoot. The GM5 module is one such thing that came up in searches.
