Key fob programming
asurber
How can I program my passenger door to unlock the same time as the drivers side without pressing the key fob button twice?
If you're outside the car and unlocking it, they should both unlock together?
If you're inside the car and opening the door to get out then you have to push the centre switch behind the gear lever to unlock the passenger door. I've tried to find a way to code it, but so far failed.
I did this with Carly, so there must be a way with NCS Expert…
Here’s the Secondary Unlock Easy Entry option on the Carly website…
Secondary unlock
• off
• Selective central locking
• Easy entry
Selective central locking’: Unlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, ’Easy entry’: Press the unlock button once to unlock all doors.
https://www.mycarly.com/blog/carly/carly-coding-for-bmw-z4/
Yes, unlocking all doors at once! I bought a Foxwell 710 hoping it could do this. Is there a certain Carly I need to get?
Secondary unlock
• off
• Easy entry
Yes but when you press the button once on an E85 it opens all the doors anyway.
I thought the OP was referring to the fact that when you stop the car and get out, the passenger door doesn't unlock.
If however, the OP means the passenger door doesn't unlock when you walk up to it and press the key fob, then that sounds more like a GM5 issue.
Quoting OP:
“How can I program my passenger door to unlock the same time as the drivers side without pressing the key fob button twice?”
Like mine, it seems like the OP’s had been disabled in GM5. As mentioned, mine was resolved exactly as the OP requires by enabling Easy Entry with Carly.
I don’t think the Foxwell can code. For E85/86, You have two options: Carly which is expensive or INPA/NCS Expert combo which is cheap (you need to buy a cable), have a Windows laptop and spend some time getting the software working.
Plenty of threads on this forum and others.
salfer said:
Quoting OP:
Fine
