Key fob only unlocks car
miscbrah
Cross posting this from the main forum - also messaged the moderator to move the thread if it’s in the wrong place :D
Hey all, just replaced the battery in my 2006 3.0si and the fob is no longer locking the car. Unlock works after manually locking, pressing the lock button seems to trigger something as the interior lights will come on if the car has been sitting a while.
Things already checked/done:
1. 2 different key pairing methods - turn to position one, 5 times, hold unlock button and press lock 3x; turn to pos 2 and then quickly shut off and the same procedure. Did get the car to lock and confirm one time.
2. With windows down and manually locking:
A. Storage between seats is locked
B. Glovebox is NOT locked ( iirc my old 2006 used to lock, is this the issue?)
C. Gas compartment is locked
Fob works to unlock the car with no issues & this only happened after the car battery died and was replaced . It’s been driven very little in the last 12 months max
Any ideas?
P.s. - I saw a post on here regarding key fob battery strength possibly causing something similar. Took the car out for about a 2 hour drive before trying to reprogram / pair , the key should have had some decent time to charge.
