Anmarube said:Kranzle for me. £800 new but goes all day every day. Can sometimes pick a kranzle up on eBay for a couple of hundred. They last forever and spares are plentiful.
Every cheap pressure washer I have had has broken within a year.
RustyZ4 said:Anmarube said:Kranzle for me. £800 new but goes all day every day. Can sometimes pick a kranzle up on eBay for a couple of hundred. They last forever and spares are plentiful.
£800!! and you have to get spares![]()
I dont know if its interchangeable (my guess is not but maybe there are adapters) but I do know that a good rubber hose makes a night and day difference to the usual hoses that come with cheap pressurewashers.csquire4 said:I have a better quality after market rbuber hose that I use with my Karcher and and I've got a Karcher snow foam attachment, are all thee things interchangeable ?
ronk said:If its for domestic / light duty use - don’t spend a lot.
If it’s for commercial use - buy the best with a good spares back up.
ronk said:A quote from Ruskin:-
It's unwise to pay too much, but it's worse to pay too little. ... When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot – it can't be done.
Havard said:Give me a reasonable pressure mains, two lambswool mitts and two buckets anyday.
Pbondar said:The Screwfix own brand Titan works very well for around £80 gets very good reviews and “pisses” on the branded ones..pun intended...
I got one and works very well with it’s own detergent tank....
I think this is the best advice (about the hose). I had the bottom line Karcher - bought with a voucher for some work done about 10 years ago, but I also bought the extension hose - good quality strong material. The Karcher went for about 10 years without any problems, working on the cars, blasting the driveway, even cleaning the sides of the house every couple of years. Never had any problems with it, and gave it to a friend last year when I 'upgraded' to a K2. The K2 just 'feels' cheaper. I don't know what it is exactly, it feels lighter, not as well constructed. But the main thing is that it came with a long hose, which I thought was a good thing, but the hose is so thin, kinks easily and constantly coils around itself. Never had any problem with the 'old' extension hose, so might have to shell out for another one (they're not cheap) to make the new K2 more usable.GuidoK said:I dont know if its interchangeable (my guess is not but maybe there are adapters) but I do know that a good rubber hose makes a night and day difference to the usual hoses that come with cheap pressurewashers.csquire4 said:I have a better quality after market rbuber hose that I use with my Karcher and and I've got a Karcher snow foam attachment, are all thee things interchangeable ?
(Thats why I also have a nilfisk e140. The version I bought came with a good rubber hose)
Very true was going to go on to say - it's also metal internals as opposed to plastic - generally speaking, petrol ones will be - and it comes with a high pressure braided line as opposed to a longer one, not to mention metal fittings where the hose attaches (meaning it's less prone to crack etc) and typically repairable components as far as mounts and nozzles go. Also having different nozzles and jets makes it much more versatile, I use a finer mist nozzle for vehicles, the lethal pencil jet nozzle carves dirt off the patio.GuidoK said:Also its better to look at the power of the pump and how its constructed internally (all metal or cheap plastic) than to look at the given pressures it has listed.
The amount of pressure is purely a nozzle matter, the smaller the nozzle, the higher the pressure, but the power of the pump, output of the pump (litres) and construction of the pump give more an indication if you're dealing with a quality unit or a cheap one.
A good independent reseller that also repairs units can give valuable advice.
And of course what comes with it: a good quality flexible rubber hose, an extension for the lance to get under the car and a 90deg nozzle are must haves to keep the underside of your car clean.
And always run the unit for about 30sec without water with the lance detached (not longer; stop when no more water is coming out of the hose) when you're done so it can pump itself dry on the inside. If water sits in there it can freeze or it can chalk up. You'll get more life out of it.
