K Bus issues
Beatman
 West Country
Hi All,
I’m hoping someone will be able to assist on this matter. Firstly a big thanks to IAmOrion for his help on this already..
Over the winter months the Z has suffered with a fair bit of water ingress, boot and passenger footwell, and during the cold snap a fair amount of internal condensation :( And I’ve tried my best to keep this to a minimum with drying out etc.
Everything has been fine up until the other week, when the alarm went off for no reason. Previous post https://z4-forum.com/forum/viewtopic.php?t=135817
With the help of IAmOrion and some Googling, I followed this guide https://www.bmwgm5.com/K-Bus_Troubleshooting.htm
As Sod’s Law dictates, it was almost the last link pulled, but all the issues cleared ( Z is on a SORN, so I can’t drive it) but I’m unable to figure out which module is causing the k bus fault.
I only have a C110 scanner so data is basic. I have been through all the modules and the below is the list of errors etc which appear. Apologies for the length of the post in advance, but I’m hoping one of you may be able to point me in the right direction?
C110 - Driver
DME CODE 2806 cruse control time out. - always had this code
EGS - NO CODES BUT IS A MANUAL.
EWS - NO CODES
EPKS - Shows unable to communicate
C110 - Chassis
ABS - 5E5B. ABS/DSC button, again this has always been there.
5E16 CAN Connection to instrument cluster
5E1F vehicle identification number different.
But with regards to the above I can see the data stream eg brake pressures etc.
EPS - NO CODES
LEW - NO CODES
C110 - body
AIC - NO CODES
CID - NO CODES
CVM - NO CODES
IHKA / IHKR - NO CODES
IKE/IKI - NO CODES
LSZ/LCM - NO CODES
PDC - NO CODES
SBSL - 9891/ 9852/ 9895. But the passenger seat is currently out. Trying to dry out the footwell
SBSR - NO CODES
SIM/SRS - NO CODES
SMF - 04 HALL SENSOR again seat is out.
SZM - 04 TEMP SENSOR as above seat is out.
VID - NO CODES
ZKE - CODE - OA,45,00,A4. NOT FOUND
CODE - OA,4T,00,B4 NOT FOUND
STVL - NO COMMS , unable to connect
STVR - NO COMMS . unable to connect
CDC - NO COMMS , unable to connect
JNAV - NO COMMS.
once again sorry for the list, but any guidance would be a great help, ps auto electrics are not my thing :rofl:
Ps the link is disconnected from the shorting bar when I took the above.
Thanks. Beatman.
