SonnyA85 said:
Again that is a myth I cannot believe people still believe.
Cars have fuel filters. What is the purpose of the filter if it allows dirt and stuff to get into the engine?
I'm also betting refineries have filters as do petrol stations, etc. I'm just guessing here but you would think that they would do to stop issues should something get in there that shouldn't.
I think all performance cars are designed to run on 95 minimum. However it should tell you in the manual if you have a look for the exact spec that should be used. Would be interesting to see what it says in the M manual. Basically the car shouldn't have any issues with 95, it will still work 100% fine. It will however run with a bit more power and refinement on the better grade stuff.
I've used a tank of BP Ultimate and £20 of performance fuel from a non major branded station. The car ran the exact same on all 3 IMO.
Not necessarily true. 2.5si and 3.0si owners should be fully aware that their car does not have a fuel filter.
It has a basic mesh strainer built into the fuel pump, but no replaceable / serviceable fuel filter.
If a car's mapping has been done so that it requires 98 RON fuel to run its best, then ideally that's what you should run. Of course you can put 95RON in there, I may run a little odd for a half mile or so, but by the time you get to that point the ECU will have had readings from the knock sensor requesting it to slightly retard the timing to keep the engine running safely.
The safety systems within your ECU are very very quick to take things away in order to keep your engine safe, but very slow to put them back.
So when you hear of people feeling a huge difference as soon as they start to run 98RON fuel, that's total bull... It'd take at least a quarter tank of the stuff before the ECU would be allowing the timing / ignition to be back in a position where it will give the optimum "requested variables". I very much doubt anyone would really be able to "feel" the difference anyway.
It'd be like asking someone to see the difference between 250ml of water and 251ml of water.
