Hi guys,
I've read all the guides, pdf's, posts, done searches and had a good look at the car myself. It's looking more costly and complicated than I first thought.
I've just got a few questions about how everyone here jacks up their car to clean the drains if anyone can share this please.
My plan is to buy a low profile jack (3.0T Arcan jack from Costco), and a pair of Halfords axle stands.
To jack up the car do I need to use the rear jacking point with the circular pad of the jack resting on the two hex nuts shown here with a block of wood in-between?
http://www.bimmerfest.com/forums/showpost.php?p=4964980&postcount=14
Then with the car jacked up sufficiently, place the axle stands underneath the plastic BMW jacking pads at the rear of both sides? Do I need anything inbetween for a flush fit here?
Finally, according to this post there is no need to remove any nuts, plastic rivets, splash guard, etc. I have spare plastic rivets just in case. Is this really correct?
http://www.bimmerfest.com/forums/showpost.php?p=4455241&postcount=5
I can't see the drain outlet talked about in the pdf with a mirror. Hopefully all will become clear with the car jacked up.
Thanks for any help.
