Facelifts are the same as M for jacking points. I use some folded shop rags to pad the jack so as not to mung up the bolts at the rear jack point, and not mung up the bottom cover at the front. Couldn't say for pre-facelifts, but should be something similar available.
For the side points, some sort of insert is definitely highly desirable. I just use a small block of wood with a screw jammed into it which drops into a hole on both my jack and axle stands.
