I did a search and found some info on jacking up the Z4 but not this specifically.
I will need to do rear brakes and rotors before my next safety inspection. I jacked the rear drivers side (US) this past Saturday to check the drain plug. I used a scissors jack without the recommended jacking pad (didn't know I was supposed to use one).
I had placed a wheel chock at front passengers side and began to lift the car. The scissors jack was leaning some but not dangerously so. When I did get the rear tire off the ground I saw the the front drivers side tire was also off the ground.
I went and checked the front at the wheel chock and body work was not too far from the ground and the chock was close to the front of the wheel well. Nothing was touching so no damage but it wasn't comforting.
Started researching and found out I should get a jack pad but nowhere on YouTube did I see where anyone was putting a jack stand on a E85.
Any help would be greatly appreciated. (photos of the jack stand in position would be great)
I have an ancient 15 ton floor jack but it would no way get under the Z and all jacks I find online seem to be marginal at best...inferior quality. So any floor jack brand that might be recommended would also be appreciated!
