Changed the starter motor for a BOSCH unit from ECP, mines was struggling and had received a few taps from the hammer.
Total time to replace was about an hour (fixing the split in the rocker cover hose took, oh, way too long, glad I noticed it...kinda).
Car burst into life, immediate turn and start so feeling quite happy with myself took the old starter back to ECP for the surcharge refund....
Problems started on the return journey, wipers were slow, ABS came on (a few others came on then off), windows were slow. Parked up and turned off/on which was a few cranks not immediate, ABS came on almost immediately. Oh brother.
Back to the house I checked the battery on DIS, voltages were dropping from what was 10V (!) down to 9V in a minute or so, warning lights on again so killed it. Battery is now on charge in the car thanks to CTEK.
I checked all connections to the starter which I'm guessing were OK anyway given it worked, turned the engine over etc. Battery was new this year so I'm not questioning that. The lack of juice going back to the battery (continual drop) suggests alternator now?? I've had none of these issues prior to fitting the starter, certainly no electrical problems of any kind.
Bad starter?? Read someone had a duffer and was sucking the life from the battery, possible?
Any help / suggestions welcome, thanks! I'm worried and really thought everything was OK initially, well it seemed to be. Surely not that unlucky to bust an alternator swapping a starter! I was careful as always removing and fitting as wires/hoses can be brittle from heat.
One thing, when I called BMW for their price <cough> he said the length was 173 as opposed to 143 (there are two listed under ECP for 2004/E85/3.0i) so I went for the 173 from ECP, they both appear the same rating wise. If it needs to come out Brexit Car Parts are getting it :thumbsdown:
Link to ECP - http://www.eurocarparts.com/ecp/c/B...91a926265513bf9e48fa05b4df8599e1d253fd&000308
