Smartbear said:I’m feeling a bit better today & tested negative, the only fly in the ointment is that mrs Smartbear tested positive at the same time :roll:
The tests are a shambles, they seem about as accurate as mystic meg
Get well soon
pvr said:Nose or throat test? The samples of the throat appear to be more accurate.
Good luck being at home, hope you feel better
For a negative result, they’re only as good as the operator doing the test correctlyFlyingfifer said:Smartbear said:I’m feeling a bit better today & tested negative, the only fly in the ointment is that mrs Smartbear tested positive at the same time :roll:
Get well soon![]()
sars said:For a negative result, they’re only as good as the operator doing the test correctly![]()
For a positive result, it’s about 99.93% accurate, as long as the operator follows the instructions. The new tests are designed for nose only, if you then use it on the throat you can get a false positive because of things you may have swallowed/consumed.
Read and follow the instructions is the best bet to have the most reliable rest.
MikeyH said:No the new ones are nose only, much nicer. Don't like the thought of sticking it up my bum though. :x :thumbsdown: Also is that before or after you stick it up your nose.![]()
Use the other one tomorrow, gives a much better result :lol:Smartbear said:False hope, i tested positive again today using the nose only kit
