enuff_zed said:Multi-pistons set in a circle, acting on alternating discs of rotors and stators. The 'pads', if you want to call them that, are multiple sections, linked together like a jigsaw to make a circle.Pondrew said:Do they have disks all round? Or drums on the back?enuff_zed said:changing the brake unit on a Tornado:lol:
The pistons compress the whole assembly, pushing from the inside, outwards. The stators are free to move in and out and all the various parts clamp up tight together when the brakes are applied.
The inside of the wheel has raised square sections which slot into corresponding cut outs running across the rotors. The stators do not protrude so far as obviously you don't want those fixed to the wheel.
To fit a wheel you first have to use a multi-pronged 'spider' to align all the brake pack components, then apply the brake to hold it all together while you slide the wheel on.
The brake units are only fitted on the main wheels.
As the brakes wear, the pads and stators become thinner, meaning the overall width of the assembly reduces. A pin is attached to the innermost row of pads and protrudes through a hole on the inner face. After every flight the pin was checked and when it became flush then the unit was replaced.
The Tornado has two separate hydraulic systems. Some major components were designed to use both systems (double piston actuators etc). This allowed for the failure of one system whilst still allowing control to be maintained.
The brakes were not deemed a vital component and were only operated from one system.
In the event of failure of that system, the Central Warning Panel would alert the pilot and on landing he would make greater use of aerodynamic braking, thrust reverse buckets and, if required, the arrestor hook which was on a simple torque tube to force it down when released.
I hope that has furthered your education a little. :wink:
enuff_zed said:Chris is on his way home with a big grin on his face.
I'm supping red wine, feeling gout coming on.
Bored now!pvr said:That way, Pondrew’s attention span can be maintained and your post count goes up.
I'm supping red wine, feeling smug.
Well my Dad is in Littlehampton, so it's not completely out of the question.pvr said:Perhaps Norfolk Rescue needs a holiday in Sussex to help me with the front shocks replacements :lol:
Heated garage and the car on a lift, what more could you possibly want :lol:
Always makes me snigger. I know I am immature! :lol:enuff_zed said:Littlehampton
That joke is even older than you, sad git!Pondrew said:Always make me snigger. I know I am immature! :lol:enuff_zed said:Littlehampton
Easy tiger!enuff_zed said:sad git!
enuff_zed said:Well my Dad is in Littlehampton, so it's not completely out of the question.pvr said:Perhaps Norfolk Rescue needs a holiday in Sussex to help me with the front shocks replacements :lol:
Happy to help if needed?
How soon do you need it done?pvr said:enuff_zed said:Well my Dad is in Littlehampton, so it's not completely out of the question.pvr said:Perhaps Norfolk Rescue needs a holiday in Sussex to help me with the front shocks replacements :lol:
That is great - there was a “misting” entry on the last MOT and that probably means that it won’t go away by itself![]()
This knuckle bolt (somewhere in the rust pile) and the spring assembly worries me
Pondrew said:Easy tiger!enuff_zed said:sad git!![]()
enuff_zed said:How soon do you need it done?pvr said:enuff_zed said:Well my Dad is in Littlehampton, so it's not completely out of the question.
Happy to do it for/with you.
I have the compressors etc.
Obviously do both sides at the same time and unless done recently I would suggest new bump stops and top mounts at the same time.
Possibly drop links too, but I'd be happy to buy those off you if not needed.
Me too, Like the Eric and Ernie "He has a small holding"Pondrew said:Always makes me snigger. I know I am immature! :lol:enuff_zed said:Littlehampton
How far is Littlehampton from Torquay :wink:enuff_zed said:Littlehampton
Well not exactly close, but I'm sure Vall would be happy to soak up the sun while I tinker with cars.MikeyH said:How far is Littlehampton from Torquay :wink:enuff_zed said:Littlehampton
"Norfolk Zed Rescue. No job too close or too far!"enuff_zed said:Well not exactly close, but I'm sure Vall would be happy to soak up the sun while I tinker with cars.
