Ok, so its the usual, you go to fix on thing and find 3 others that need work.
Today Ive had a wiper motor problem, but whilst the bonnet was up noticed this hose has come away. Any idea what it is and how urgently i need to find a replacement part?
Yep, quite important.
You’ll notice a whistling noise probably and a drop off in power due to the loss of vacuum.
New inlet manifold hose required. Thay all go at some point.
Looks like a clean break so you may be able to temporarily bond or tape it in place.
Looks like you may be able to remove the broken end piece from the connector then place the connector in that new hole in the inlet manifold hose and secure with strong tape for now.
Better still, dont drive it until u replace the hose.
