is this correct?
Got a sidelight bulb - thought xenon's don't have a sidelight ? Easy to be misinformed... The ad for mine said it had xenons and I thought it did because the low beam looks xenon-ish... till I found out on here after I bought it :slaphead:
I have a sidelight but my headlights are not bi-xenon - the main beam is xenon but the high beam is halogen. You could ask if it comes with the xenon ballast?
Difference between single xenon on the pre-facelift and bi-xenon on facelift ? Have to confess I don't know if there is a difference between models, but I have a facelift with a sidelight and both my bulbs are halogen. I know cos I changed all 4 bulbs recently.
The picture of Alex's lights are bi-xenons from a facelift model and the ones on eBay are xenons from a pre-face lift I think. The inners on the bi-xenons are just blanks with a halo as side sights.
The printout of options on my zed states xenon for low and highbeam. I was told that they fix the halogen for flashing because xenon is too slow and its not good for the bulb. When you switch to high beam with xenon the lens is adjusted so you get further with the beam. But also engages the halogen because you well have them so why not use them too?! But I could be misinformed.
fair point but I thought after facelift the ambers were removed from the headlights?!
Pre facelift Xenon units with clear indicators exist too. Not cheap.
c.£700 plus VAT (EACH) and that's without ballast or igniter.... :(
