is there a how to guide on pollen filter replacement
Sky-drive
I had a search on the forum looking how to replace the cabin pollen filter but no luck - any help with a suitable link? Or failing that any advice on how to change it.
Ever so easy, did mine yesterday in about 5 minutes. A Google search will bring it up, but basically undo two screws holding the plastic panel on under the glove box. You will see a ridged cover near the back of the footwell, this pings off from the larger end nearer the centre of the car. Pull the filter out. Put new filter in and replace everything. Hoover the leaves & detritus up that fall out on to the footwell!
Make sure you get the right one though, the auto air con ones are different.
And make sure you note which way the old filter comes out, note the arrow direction.
I'm pretty sure there's a how to on youtube.
As Paulr said - 5 min job.
try this. This is for a LHD car, but its the same method. I did mine not that long ago. There was no module attached the panel so I only had to disconnect the footwell light to remove the panel completely.
https://www.youtube.com/watch?v=QBQXUpvdDQ0
