Is it possible to display IAT data on the dash?
enzed4
New Zealand
Just putting it out there - can you display any info other than speed on the E89 digital dash?
I'd like to log some IAT's as I'm looking at a new intercooler soon. I want some comparative data to see how much difference it makes.
Failing that, I have carly with the BT adaptor now (have always used a cable but wanted to try some features only available with the adaptor) so i think I can show the info using that (on the phone screen). Not sure if Carly can log the data or only show real-time info? If the latter, might have to look at another solution for logging - any suggestions?
Thanks.
MHD will allow you to display real time values on your phone, IAT, Boost PSI, Fuel Rail Pressure, and a myriad of other options.
I personally used my phone mounted in the cd slot.
The closest you will get to having it on the dash, is having it on the idrive using some sort of hdmi adapter iirc. But the cic screen is pretty low resolution so not ideal.
Also MHD will allow you to log, so you can do some pulls and see the iat and other values logged and graphed.
Great info, thanks :thumbsup:
