iPhone4 Snap in Adapter Update
wegras said:
Yes the iPhone4 adapter will fit BUT you have to remove two small "wings "to allow it to drop down ....will be obvious when offered up which bit needs to come off .Once removed fits as the same part in the 1Series A Dremel sorted it in seconds
You do of course need the latest (ie 3G/S) eject box the original will not fit any iPhone
So you dremel off some wings from the iPhone 4 snap in adapter, and then the latter fits into the eject box designed for the 3GS?
Photos please!!
Yes two narrow ledges at rear of the cradle each side .They stop the cradle dropping into the eject box. cut / dremel them off and the cradle then drops down and clicks in
I have two iP4 cradles , one in 120d which fitted perfectly and the minor adjusted one in Z4 which is a facelift .
Sorry don't use pic sites so don't do pictures
