Changes from V6.02-7045
Added invalidation of ID3 tags on receipt of broadcast ID3.
Added debug printf when processor volume reported is not the volume requested.
Added 1 second timer on setting the processor volume, if the timer times out then the volume request is sent again.
Added debug printf on changing the processor source.
Added option to display the Journal and Vehicle Status in full screen mode on a MK IV Nav.
Added PXA Direct option which when selected causes the AI-Net port to be used when the Intravee source is selected.
Added switch of Processor source when PXA Direct is selected and a Nav command is detected.
Added light sensor trigger level for Entry and Exit lights, the will probably only work on the E46, maybe the Z4 and X3.
Added retry up to 10 times on sending light control messages if no Ack is seen.
Changed the mechanism for display disable when Intravee is paused for Phone or VR.
Change to FID audio menu update frequency.
Changed OPARM version to 64.
Fixed bug when changing the processor volume while reduced (in reverse) changing the volume now cancels the reduction.
Fixed bug when setting the clock from the Nav when the TZ setting was more then 9.5 Hours or less then -9.5 hours.
Fixed bug that caused the Nav type to be requested on power when in auto UI mode up even if the Auto Nav type setting was not selected.
Fixed bug that prevented VR commands being heard when using PXA Direct mode.
Removed debug printf on Net App restart.
http://www.muga-uk.co.uk/intravee/fw-app-256-extrasv6.02-7058.zip
http://www.muga-uk.co.uk/intravee/intravee_users_guide_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/intravee_extra_features_supplement_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/intravee_PXA_supplement_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/intraveeutilities.zip
