I installed the intravee into my Z today. Is there any advice on what settings I need to choose or how to get the best use out of it? I have nav and DSP.
Welcome & exit lights are great, zoom on sat nav is ok, triple blink on indicators is great and you can set the number yourself up to 11.
Reversing sensors display is interesting.
Reminds me, must sort out how to get the display to revert back to Nav after changing track or similar. though it would be the display time out but appear not.
There was a specific mod to enable the timeout on the Z4, can't remember exactly when it was or if you need to activate it specifically! I'm away from home right now, but I'll let you know when I'm back, can remote in or remember!!
With all Nav radios except the CID in the Z4 (and maybe the CID in the X3 too), if you change tracks with the Map/Menu/OBC screen displayed it will switch to the audio screen for about 6 seconds and then back again. With the Z4 CID it will switch to the audio screen but not back again.
A delay timer was put in the Intravee firmware to counteract that. The default time is 12 seconds, so if you do nothing for 12 seconds it should switch back again. there is also a console command "smtt XX" where XX is the number of seconds after which the screen should toggle back.
