Intermittent Stuttering & Dash Lights – Possible Ground Strap Issue?
jasecasecarr
 Gloucester
I’ve got a 2004 BMW Z4 3.0L (E85) and I’m dealing with some intermittent electrical issues:
Symptoms:
  • Dash lights flicker randomly, but when they come on, the Engine, ABS, tyre pressure, and handbrake (amber) lights stay on
  • EML and battery lights flash intermittently when it acts up
  • Car sometimes runs okay for a bit, then flickers or stutters, and I’ve even had it cut out at low revs
What I’ve done so far:
  • Replaced the alternator about a month ago, seemed fine initially
  • Battery is fairly new
Observations:
Issue happens randomly, not necessarily worse when warm
Questions:
  • Is the logical next step to check/replace the earth strap grounds?
  • Do I just need to change one ground, or all three?
  • I’m guessing you have to get under the car or use a ramp.
  • I can’t really find links for the ground straps, any suggestions on where to source them?
Any advice or experiences would be greatly appreciated. It just a it stressful as is… 😬
Cheers Jason
Are you sure the battery terminals are on tightly?
Is the alternator charging properly. Check at the battery for around 14.2v when running.
Have you put a code reader on it?
Pretty sure battery connected tightly, when first attached battery was checked and output was fine… the ironic thing is I have found a C310+ code reader was going to collect today but didn’t want to make journey.. but know having the codes will help thx
Codes may well help
As others say- get your codes or you get lots of pointers that will be expensive but may not solve your issue
Here’s one for you- I had the same symptoms when I had a failing DME
So deffo use the 310 to get codes
