EViS
Our 2003 Z4 e85 has had a very intermittent orange battery light coming on the dash for the past year. It's never caused an issue, but is something I've wanted to solve.
The Bosch alternator (and belt) is new and shows a 13.7v reading at the battery terminals with all accessories running. The Varta Silver battery is only two years old. Halfords ran a battery test and the readings seemingly came back good, but are these completely fool-proof to ascertain that the battery definitely wouldn't be the culprit of an intermittent battery light?
Battery: Good
Rating: 780 EN1
Measured: 688 EN1
Volts: 12.60 V
Int R: 3.60 mOhm
Life: 83%
The next step is probably to check the earth contacts. Is there a detailed diagram somewhere which shows ALL of the earth points on the e85? I couldn't find anything obvious in TIS.
Is there anything else which could be causing an intermittent battery light which could help with the diagnosis?
Battery: Good
Rating: 780 EN1
Measured: 688 EN1
Volts: 12.60 V
Int R: 3.60 mOhm
Life: 83%
