Interior Lighting connector location in passenger footwell
Corkbro
 Ireland
Hi All,
I’ve had my Z4 for 4 months now and the forum has been really helpful, but this is my first post.
I just did the GM5 module repair, and after reinstalling, everything works perfectly. However I inadvertently disconnected the wiring for the interior dome light in the passenger footwell, does anyone know where it plugs back into?
Thanks in advance!
bigwinn said:
The connector in the 3rd photo
Hi bigwinn,
Thanks for the reply, and yes that’s the connector in question.
I’m looking for the location to plug it back in, would you or anyone be able to point it out for me? Cheers
Corkbro said:
Hi bigwinn,
If your car has footwell lights they are fitted into the trim panel you removed, so simply plug it back in.
If it doesn't have them then you should see a rectangular hole in that panel where a light will fit.
To test the loom, fit the light from the boot to that plug.
If it works then get yourself two interior lights, fir one there and find the same connector on the drivers side and fit one there.
