I’ve removed my bezel and realigned my tachometer; however, every time I reconnect it to power the needed drops. I’ve tested the cluster. I’ve done about all that I can think to do. Any advice? I’m not finding much help online.
You’re best off taking them apart. Then plugging them in without the plastic lens on.
You can then pull the needle off and put it back on the correct position with the ignition on.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
