Fast3000 said:Another one to check....have the wheels ever been refurbished? If yes check the inside of the wheels...sometimes a slight bit extra paint, lacquer can throw off the balance....
There is a lot of trial & error regarding Z4s & this "twitching + tramlining " issueFast3000 said:@mr wilks & OP my zeds steering wheel use to oscillate. Albeit not unstable at speed. Got it sorted as it by rectifying the issue mentioned.
BranNubian said:I used to suffer from the exact same effect, and as @Dewi mentioned it was due to a back spring being broken.
I had both back springs replaced yesterday by BMW, is still early days, but I can already feel a big difference. The car feels more centered and composed...I have yet to give it a good highway test. I'll report back, with results in a few days.
gordongecko500 said:Hi
Sorry I can't help much but I am reading this thread with interest - I have a 3.0Si coupe 2008 with 49k miles - I have had the oscillating problem on and off from the day I bought it. It's irritating but I still have RFTs which I will be swapping out next year. I've driven a number of bmw over the years but the zed is very twitchy. it may have a top speed of 155mph but I'm not sure I'd want to ever go there due to its unpredictability.
Still love it though!!
stupot67 said:Hi,
Just another thing to try, have you had the wheel/tyre assemblies road force balanced?, I had a similar issue on an X type I had (65-75 mph oscillation thru steering wheel and a feeling of instability, gone again at 80+). Normal balancing showed no problem, after the RFB all was good again.
Stu.
Gonzo said:I had similar symptoms at motorway speeds with the steering feeling very vague with a tendency to wander. I've just had my e86 aligned on a hunter setup and its very much improved. Would recommend you look into a reputable place as most don't charge for the alignment check and then have set pricing per adjustment.
If you are anywhere near Leeds/York/Wakefield then I'd recommend Bram Racing in featherstone.
If you do get it done, make sure they weight the car correctly before checking/setting up.
