Can I reset this warning I get when I turn ignition? I did the
1. Ignition in the off position.
2. Push and hold the trip reset button while turning the key to position "1" or Accessory.
3. Continue pushing the button for 5 additional seconds until the display changes and "inspection" or "oil service" appears.
4. Push the button again for approx 5 seconds until " Reset " or "RE" appears in the display and is flashing.
5. When the display starts to flash press the button a third time to actually reset that item. The new or updated service should appear and you can now shut the key off.
this worked a treat to reset the oil service warning but it doesn't seem to work for this Inspection warning light.
