Indicating new posts box gone?
jamie_z4
Veteran
Find it bizzare that the forum update has lost the box that took you to the latest unread post?
Every other forum has this and removing it just looks like all the threads in new posts have been read already?
Any reason for it or alternative way of viewing that red box again.
Thanks!
Yep, I've still got it - that's where I found this! :)
On my phone I always use the drop down menu from the top right and select New Posts, and on my iPad I use the New Post button at the top can’t see that anything major has changed ??
Although on my phone I can now see the author of the post and the last poster :thumbsup:
Stuart
firebobby said:
Also missing on mine, although I now use the circle thing next to the threads
That doesn't help me though as it makes it just look like it's a new post not something I haven't seen since I last logged on
It will differ across devices. Different mobiles have different numbers of rendered pixels and some may fall below or above a CSS breakpoint that decides it it should hide or show for a particular resolution.
Id be interested to know which mobile devices the people are using that can't see it, compared to those that can. I'd expect those that can see it have phones that render more pixels. For example phones that have top end screens will probably see it, and cheaper phones with less resolution won't.
For those who can't see it on their phone try turning their phone and see if it appears in landscape mode? If my theory above is right then it *should* display there as you should have a larger number of rendered pixels in that mode
Ok, hadn’t realised it had gone, it wasn’t deliberate. I’ll take a look this evening and see if I can fix it.
Just looking into this and it seems there is duplicate functionality. The old icon was just the same as the bigger icon on the left when there are unread posts. Clicking on the red icon on the left goes to :
viewtopic.php?f=1&t=104132&view=unread#unread
This is the same location the old smaller icon went to.
