Pondrew said:FWIW
My E89 (2013) has an AGM battery aswell. No idea whether it's original but it has a BMW sticker on it. It also holds it's charge really well.
Mine lasted 11 years and I've replaced it with an identical varta agm battery
Pondrew said:FWIW
B21 said:So far all the batteries we’ve seen are AGMs..AGMs are a subset of the general description of lead acid batteries.
AGMs have a different chemistry as well,as physical changes.
The charging profile is different hence why most modern battery chargers have an AGM option.
Given that all UK E89s have regenerative charging that always goes hand in hand with AGM.
E89s never fully charge their batteries..they leave residual capacity to allow regenerative charging to take place.
Without the correct voltage profile the calculations for all subsystems will be slightly off.
Non of my E89s have stop start but all came with AGM batteries that’s a 2011 and a 2012 MY![]()
Zforbes said:The pic I posted of my original battery I'm pretty sure is not AGM, it's BMW stickered and dated week 23 2010 so I assume is what left the factory when new.
Quick Google on the part number and results come in as non AGM so that's what it got early this year. FWIW whilst I may have a few minor issues with the car, I can't attribute any down to the battery.![]()
Pondrew said:This is just a guess so don't shoot me:
Maybe cars without stop/start originally came with non AGM batteries and ones with S/S did. That would make sense to me, as the AGM for a given physical size (to fit in the hole) would be higher capacity.
Most batteries are changed at some point, so are generally then changed for an AGM regardless?
Blows my theory out of the water, then.Zed Baron said:Pondrew said:This is just a guess so don't shoot me:
Hi Pondrew, my e89 is an early car without stop/start and its an agm battery (week23/09) that was originally in it20200620_220533.jpg
Pondrew said:It could be as simple as 'whatever was available' on the production line; ie they had a few standard lead acids but mostly AGMs. Doesn't seem very German, though![]()
Zforbes said:Don't want to appear a smart arse, genuine question. What tells you it's an AGM battery?
Zforbes said:Zed Baron said:Pondrew said:This is just a guess so don't shoot me:
Zforbes said:B21 said:So far all the batteries we’ve seen are AGMs..AGMs are a subset of the general description of lead acid batteries.
I'm not doubting your knowledge here and appreciate opinions.
B21 said:Zforbes said:B21 said:So far all the batteries we’ve seen are AGMs..AGMs are a subset of the general description of lead acid batteries.
You can tell your original battery is AGM by the ratio of ah capacity to cranking capacity…yours is 70 ah and 760 cca
An EFB battery would be 70 ah and 600 ish cca![]()
Example here.. https://www.tayna.co.uk/car-batteries/powerline/096efb/?gclid=CjwKCAiAh_GNBhAHEiwAjOh3ZBbMiB5iEMBtPb820O_bF82W3pg5CT8Jgs9s_EfU1d-B7dS8Sq9XoBoCCoEQAvD_BwE
I can't see why it's the 'wrong' battery, just not quite the same credentials as OEM.Zforbes said:I'm becoming resigned to the fact I've got the wrong battery on my car although the battery I bought is a yuassa with 80ah 740 CCA from a local motor factors like this one
Pondrew said:I can't see why it's the 'wrong' battery, just not quite the same credentials as OEM.Zforbes said:I'm becoming resigned to the fact I've got the wrong battery on my car although the battery I bought is a yuassa with 80ah 740 CCA from a local motor factors like this one
At the end of the day as long as it starts the car easily, runs all the electrical circuits and keeps doing that by charging from the alternator, then it is fine.
Yuasa are a good make and the underlying amperage figures are very close to the OEM. And if you paid 87 quid I'd say happy days.![]()
You are coming from a different perspective, though, Peter. You are coming from a 'technology' perspective, I am coming from a 'practical' perspective.B21 said:Sometimes no matter how much you try to annunciate a point people seem to fail to grasp the point![]()
The voltage profile of an AGM battery is different to other lead acid batteries.
Therefore the systems that charge the battery and do a myriad of complex calculations across many ECUs on the E89 are being fed with erroneous data as a use of using the incorrect technology….
Therefore predictions on how long various systems should run for and when to sleep and when and how much to charge the battery will all be incorrect.
How incorrect and in what forms I don’t know but they will be incorrect….whether it has a profound effect on anything is debatable, but it’s not right…certainly it would fail the proposed anti tampering law![]()
Pondrew said:You are coming from a different perspective, though, Peter. You are coming from a 'technology' perspective, I am coming from a 'practical' perspective.B21 said:Sometimes no matter how much you try to annunciate a point people seem to fail to grasp the point![]()
It's a ferking battery which is filled with lead and sulphuric acid, not a nuclear reactor.![]()
I still don't understand why people think an exact like for like replacement part is the only option...apart from ignorance...B21 said:I still don’t get why people buy a ‘performance car’ then put sub optimal stuff in it..apart from ignorance…
