AldridgeZ4 said:I installed a Grom unit (BT3) I think it was called. It gives Bluetooth connectivity for music and calls ( comes with a microphone). But also has a lead for charging and wired playback that can be controlled from the stereo or mfsw.
It's a bit hit and miss to get working, and the interface is awful....but it does the job...just.
Monkeydonkeyratmagic said:The cables for these units are pretty pricey. Best off getting a 12v fag lighter to usb.
Other than that you have 3 choices for BT and calls.
Grom
Dension
Intravee
Cables are £30 for a plug in interface
R60BBA said:Monkeydonkeyratmagic said:The cables for these units are pretty pricey. Best off getting a 12v fag lighter to usb.
Grom
Dension
Intravee
If I plugged my iPhone into the usb - faglighter, how could I play music at the same time though?
R60BBA said:I’ve heard about these Grom thingys.
You got any pics of your set up?
Good idea. I've used them on holiday to keep the smart phones running map and translation apps, but never thought of using it in the car.I bought a medium sized one, fits in the palm of our hand, and it kept 2 large screen phones running all day and night when we were getting lost and confused in Japan.skelters said:Have you thought of getting a portable battery as the fag lighter is usually crap charging anything.
https://www.anker.com/products/107/201/High-Capacity-Portable-Chargers
Can usually charge a phone about 5 times before you need to recharge it. You can also charge two devices at the same time.
ph001 said:Why would the fag lighter be crap at charging??? It just gives 12v out. It’s the 12v to 5v converter that you plug into it that does the tricky bit.
