Bonsoir Zedders.
Once I've worn out the OEM items I will want to change the pads (Ferrodos?) brake tube pipes to steel lined ones and perhaps the liquid.
Question - I understand the disks are the same as the CSL's brakes on the Z4MC but are too thin (4mn) to take regular and prolongated abuse. I'm thinking that maybe if I interfeer with the OEM set up then increased heat and pressure will crack them, in which case I might as well save and just go for the full monty (AP 6 pistons + 4 - which is just unnecessary for the emoment concidering I'm at the bottom of the learning curve oin track and am fairly careful and sympathetic.
Any advice sil-vous-plais?
