Jonny essex said:Lovelypaddy wright said:foot well light plugs are there- they are taped back- I found them and added footwells to mine.![]()
On that note, where to get foot well lights?
Jonny essex said:Straight from the US of A, hand made and unique and waited a month for them.....£300 with import tax![]()
Only issue is that i have to run these from the footwell light with a scotch lock however i dont have a footwell light, will the power supply be there already or is there additional wiring for me to do?
Jonny essex said:Reading both readups, it seems i have to run the wires from both door sills to the main modual on the passenger side? Also unsure of what wires go where as mine are both black and one has a faint white line which i guess is the positive, any help with where wires go into modual with the scotch locks?
Jonny essex said:No mate, u free anytime next week im off all week.Smartbear said:Hi Jonny, have you got a multi meter you can use to check for voltage? I have one you could borrow if it helps you out.
pvr said:If they are, there is indeed a very good chance that you have the polarity the wrong way around.
