Can anyone explain accurately what the ICV does, and whether it ceases to be functional at a certain Rev band.
I have stripped and cleaned my M today and have totally eradicated the hesitation... It's like a different car. Couldn't get it to kangaroo at all.
When I removed the ICV it didn't make a noise at all despite shaking, tilting and twisting it. I flushed it with carb cleaner and still no clicking, I left it for about ten minutes and it then seemed to free itself and clicked freely.
I know the hesitation has been widely discussed on these forums but I noticed that the TPS in linked to the ICV as is the MAF wiring I think, it also seems that the two pipes link the air box with a direct link behind the throttle butterfly's. Hopefully someone can explain this better and confirm if it is linked as previously mentioned.
I use my M very little only covered about 600 miles in the past 6 months, could the ICV be prone to sticking on under used Ms causing the hesitation.
If anyone is suffering from hesitation it may be worth removing the top pipe where it comes through the throttle bodies, spray a little cleaning fluid in and leave to evaporate and then see if the hesitation improves, may save undertaking a big strip.
