Hydraulic oil capacity when relocating the roof motor
penant78
Hi,
I know that the level of hydraulic oil must be within the + sign.
But when we relocate the roof motor in the boot, it is usually at an angle of around 45 degrees.
Do we need to keep the same level or add a little more oil as the reservoir is no more horizontal?
Yes. You need to add a little to compensate for the angle otherwise it will suck air. Make sure that the entire base of the pump reservoir is covered.
(It doesnt make any difference if the roof is up or down, the level stays pretty much the same)
