Hubcentric spacers, 12mm fronts
SqerrNipz
 Oxford
Precision engineering hubcentric wheel spacers. 12mm fronts. Fitted to car for about 5 minutes, however bolts nsf catch on dust shield (I think fixings are broken and it’s a bit loose).
£30 delivered.
Original info from ebay ad -
Precision Spacers are lightweight & durable fully hubcentric alloy wheel spacers.
72.6mm centre bore on both internal and external faces.
Drilled for 5x120mm PCD Fitments.
Fully hubcentric means no issues with wheel balance.
Improved cornering stability as track is increased by 24/40mm.
Wider stance give more aggressive cosmetic appearance.
Plated to ensure a quality finish which endures.
Bolt Information -
Supplied with the appropriate extended bolts for 12/20mm spacers.
60° Taper Seat suitable for use with Genuine & Aftermarket Alloy Wheels.
10.9 Grade Carbon Steel.
Bolt shaft length 40/45mm, bolt dimensions: M12x1.5x40/45mm.
