Okay, finally got pics uploaded to Photobucket. Not hijacking srhutch's thread, more supplementing
So, the paddles - dead easy, just undo the torx screws circled in red. They slide out, but are still attached with wiring so I just flipped them back to sit on top of the control stalks.
Now the finished article. I didn't have grilles to practice on, and I didn't seem to get as good a finish as srhutch. In fact I stripped the plastidip off three of the parts completely and started again because I messed up the third coat - figured out that I didn't clean the nozzle of the can between uses, which resulted in spatter and bubbles in amongst the spray, if that makes sense. To be honest, the first and second coats looked dead smooth, it was the third that always roughened it up. However the results aren't bad, and better than shiny plastic which the under-colour was beginning to show through :
The bottom looks a bit rough, needs done again if I am honest as I marked it slightly when still tacky :
And finally the edges, which as remarked upon above do seem to lighten up after use. I can confirm some spit fixes this
, so I reckon some rubber treatment might help it hold it's shine :
It is no longer tacky/overly grippy - though I left the bits out in the sun for 4 hours before re-fitting. It looks much better, and actually I am happier with the bits fitted as the wheel looks newer (though the leather is now showing up as worn more than it was :roll: ). If it all wears off too fast then I may do them again, or perhaps get them spray painted matt black by a local chap. The only issue with that may then be chipping. However, a great wee fix championed by srhutch
