Mark-Z4 said:Does the centre bolt holding the wheel on need to be torqued and if so what is the torque setting?
Mark
The purists will say yes - I just used the old ways and tightened it till it wouldn't budge - 3 years on all good
Mark
MrGringo said:the cost of the cable has risen from £5 to £17. £17 for what is essentially two wires seems mightily expensive. If you can locate the scotch lock connectors elsewhere, you could order two bushing contacts (part 1) from BMW and use those, only thing you'd need to remember is which is which as they'd both be black.
It's part number 61130006663 and only £0.98 for 75cm cables (which you can trim to the size you need). (item 1 on the bmwfans link)
So £2 vs £17.
There we are, hope some of you benefit from this!
