bigwinn said:Never seen that
Assume it’s auto box?
I’ve only dealt with manual car columns
Do you mean column replacement or just the cable?V Vette said:I need to replace mine.. Any help where this is and what do I have to remove? I assume it goes into steering column some where and down to the automatic shifter? Is this easy access? Thanks
enuff_zed said:Do you mean column replacement or just the cable?V Vette said:I need to replace mine.. Any help where this is and what do I have to remove? I assume it goes into steering column some where and down to the automatic shifter? Is this easy access? Thanks
If it’s the column then just unscrew the cable from behind the ignition switch.
Just the cable . But I have no clue where it starts and whee it ends. Do I need to take apart the ignition? Where does it get connected to in the shifter area? How much is involved? Thanksenuff_zed said:Do you mean column replacement or just the cable?V Vette said:I need to replace mine.. Any help where this is and what do I have to remove? I assume it goes into steering column some where and down to the automatic shifter? Is this easy access? Thanks
So the picture you show is the part you unscrew, is that the rear of the ignition? Not sure what/where that picture is from ?enuff_zed said:It unscrews from behind the ignition barrel but no idea where the other end goes. Sorry.
Not my photo, but if you take the lower steering column shroud off then look up from underneath you will see the cable attaches on the right side just a bit lower down than where the the key goes into the barrelV Vette said:So the picture you show is the part you unscrew, is that the rear of the ignition? Not sure what/where that picture is from ?enuff_zed said:It unscrews from behind the ignition barrel but no idea where the other end goes. Sorry.
DMike said:Hi,
Never done it myself, but in TIS two documents, 32 32 170 and 25 16 175 explain the procedure to change and adjust the cable. Won’t post copyrighted material on the site, but maybe you can find them. Too complicated to describe in written, you need the pictures in TIS.
DMike said:Hi,
Technical Information System, BMW’s acronym for their technical documents. They are copyrighted material so won’t post any links on the forum.V Vette said:DMike said:Hi,
Also what is TIS? where can I get this as I only need to adjust cable.Thanks
